NX MAF kit with a 90mm tb/intake
Old Feb 23, 2005 | 09:11 AM
93LS1RX7's Avatar
Default NX MAF kit with a 90mm tb/intake
Dave/Ricky/Smart guys
I dont want any restrictions in my intake so I am looking a what I need to do to get my 90mm TB/Intake to work with the NX MAF kit. What is the anwser? Obviously the stock housing that comes with the kit is probably 75mm, how can NX help me solve this problem? Do they have a MAF housing for 90mm or 85mm (Which ever is the biggest available) with the bungs?
Thanks
Mike
Old Feb 23, 2005 | 11:18 AM
JS's Avatar
JS
I saw a NOS plate for the C6,I wonder if it bolts up to the LXS too...The C6 runs a 90TB so it should work on an LSX intake/90TB setup on out cars?Its pretty nice,sorta like a spacer with the nitrous fittings on the side of the plate.
I think it would make for a nice install too.
Old Feb 23, 2005 | 01:05 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Which MAF sensor are you using? Here is a pic of a prototype I built, going to tweak the overall look but I think it will give you a look at a new part.
Ricky
Old Feb 23, 2005 | 01:14 PM
JS's Avatar
JS
So will this bolt up to any 85MM MAF or just a C6...
Is it going to be both 1/2 or just the rear 1/2...
Looks very nice...
Old Feb 23, 2005 | 01:17 PM
93LS1RX7's Avatar
I will probably end up with a Pace or a Z06 85mm MAF. I havent seen a 90 that is compatible with the LS1 without getting crazy in cost.
It looks good Ricky, any chnce that center post could be thinner?
Old Feb 23, 2005 | 02:16 PM
NXRICKY's Avatar
Looks very nice...
The I.D. measures 89.4MM at the outlet and 86.36MM on the inlet. Measured another maf unit same.So I guess we will call it 90mm. The metal unit that goes on to these maf sensors (from the picture) measures 90.678 MM..
THE one in the picture is epoxied on, the new ones will use 3 bolts to hold them to the sensor..
Center measures the same as the stock sensor, so really no need to thin it out. The Aluminum part will work on any of these type of maf units..
Ricky
Old Feb 23, 2005 | 03:04 PM
2001 Pewter WS6's Avatar
Restricted User
Now the big question.... How much??
And also how much is a power ring for the 90mm TB?
You can pm me a price.
