More power: No2 vs. timing
Old Mar 3, 2005 | 10:45 PM
Beast96Z's Avatar
Default More power: No2 vs. timing
In my givin scenario, would it be better for me to run a 150 shot and more timing, or a 200 shot and less timing? I'm limited to 93 octane and I'm not sure how much "extra" timing would have to be pulled to make the 200 shot/93 octane work. I'm wondering where the point of octane/nitrous/and timing start to rendor useless.
Old Mar 3, 2005 | 11:30 PM
Gregg 00SS's Avatar
I highly doubt the timing needed to be pulled would take away more than 50 HP, so you would most likely come out on top by pulling timing to run a 200 shot. However, the question then is can your engine/fuel system support a 200 shot.
Old Mar 3, 2005 | 11:34 PM
Beast96Z's Avatar
Yes, it's a forged 383 with a Bosch 420 running through a -8an feed to a -6an return with Aeromotive regulator and fuel rails.
Old Mar 4, 2005 | 12:38 AM
CAT3's Avatar
Restricted User
Agree go 200shot. Reducution in 2* per 50hp for juice. And typical timing increase in power output is around 2-5hp per degree. So, if you added a couple degree you'd most likely see max of around 10hp, yet if you decrease timing and add nitrous, you get more around 50hp!
Old Mar 4, 2005 | 05:36 PM
Beast96Z's Avatar
Sounds good.
