factoring in my cost.....
Old Mar 4, 2005 | 08:41 AM
ws6nick's Avatar
Default factoring in my cost.....
Will I need a tune when I install my kit (150 shot).
Old Mar 4, 2005 | 12:31 PM
GM Muscle's Avatar
150 is kind of boarder line. Assuming it's a wet kit the only real issue would probrably be the timing. Plenty of people run stock tunes with a 150 shot no problem but I have seen others pick up some detonation. If you havn't bought all your stuff yet I would do this. Instead of spending $100 or more on a Window Switch, buy a timing tuner for $250. That way you can control your timing on and off the bottle and it has a built in window switch and I believe a 1st gear lockout too. Either way I would atleast spend the money to get on a wideband and see where your A/F ratio is at.
