ok new to n20, need tips on install?
Old Mar 10, 2005 | 09:21 PM
crAzy95Z28's Avatar
Default ok new to n20, need tips on install?
ok i got a compucar 100 shot wet kit...
going with the 100 for now..
i have a WOT switch, fpss, purge and msd window switch with 3k and 5800 pills....will be geting a bottle heater soon...
ok where exactly do you moutn everything?
i know bout mounting the bottle in the rear tire comp, but where do you run the n20 lines and things?
and i will prob be putting my wot switch and purge inside my lighter compartment on the side....where can i run those wires to get through the fire wall?
please all tips and helps will be great!!
Randy
Old Mar 11, 2005 | 08:13 AM
02transhawk's Avatar
If you are installing in the spare tire well, then take out all the plastic on the passenger side, run the lines along the door panel, pull the carpet up and underneath the glove box is a factory hole w/ rubber bushing that should be large enough, use a coat hanger to push the lines through, they will come up behind your battery. I know this is fine with the m6, and I believe the A4's are setup the same way. Should work!
Old Mar 11, 2005 | 12:23 PM
crAzy95Z28's Avatar
you are talking about the metal/aluminuim lines right? not the wires!!
