mounting the WOT switch?
Old Mar 15, 2005 | 12:05 PM
crAzy95Z28's Avatar
Default mounting the WOT switch?
where in the hell do you mount this thing? lol...
im soo lost....it is the NOS one...
Randy
Old Mar 15, 2005 | 02:43 PM
john3daly's Avatar
Take your bracket. Bend it like the directions say, cut off the end of it, and then mount it on your throttle body with the switch on it. When you go WOT it should then, and only then, be activated. Some guys mount it under the gas pedal as well. Make sure that it won't hold your throttle wide open. Be sure it will NOT get hung.
Old Mar 16, 2005 | 02:08 PM
Shuck's Avatar
I just mounted mine on a screw out of the TB and bent the bracket.
Old Mar 16, 2005 | 04:34 PM
fastbird96's Avatar
I mounted mine from the top bolt on the throttle body. I just had to make two small cuts on the cable cover for clearance for the switch.
Attached Thumbnails mounting the WOT switch?-wotswitch-05.jpg   mounting the WOT switch?-wotswitch-06.jpg   mounting the WOT switch?-wotswitch-09.jpg
Old Mar 16, 2005 | 04:59 PM
DopdBrd's Avatar
Jimmy Jams!!!! give him a call or go to his website. PM me and I'll send it to you very nice bracket and all I had to do was bolt it on.
Old Mar 16, 2005 | 05:11 PM
ITSTOCK's Avatar
Here you go...this is on my car, but my brothers WS6 is the SAME EXACT way...
