How will a car run....
Old Mar 15, 2005 | 09:05 PM
Phil99vette's Avatar
7 Second Club
Default How will a car run....
How will a car run on the motor back and forth from the track if its say setup for a 250-300 shot with pulled timing and colder plugs? I am trying to figure out if it is feasable to drive to the track with this setup.
Phil
Old Mar 16, 2005 | 09:35 AM
next's Avatar
I notice a lot of carbon build up on my plugs which it is a symptom of running too cold a plug on motor. It just forces you to change the plugs often, which is always a good thing for nitrous anyway.
Old Mar 16, 2005 | 03:25 PM
Homeslice (tm)'s Avatar
Phil
I do it no problem.
Old Mar 17, 2005 | 12:38 PM
slow trap's Avatar
can you run a timing tuner ? that way you can use your n/a timing until the n20 tuner retards your timing when activated.
Old Mar 17, 2005 | 01:16 PM
white2001s10's Avatar
yes a cold plug can do that, but you can just sand blast them to clean that off, and I normally hit the tips with a propane torch to cook any liquids out of the insulators before I put them back in. You can reuse a nonresistor AR472 plug many many times before having to replace it.
In cold weather, the cold-start enrichment (CSE) is especially hard for cold plugs to take so I use a CTS tricker box to get out of CSE as soon as possible which is normally a minute or two.
Old Mar 17, 2005 | 01:19 PM
Z284U2TRY's Avatar
What shot you guys run?
What plug you guys running?
What fuel?
How much max timing?
I am in the process of ssetting up a dirt port 300.
Old Mar 18, 2005 | 02:47 AM
WOT's Avatar
WOT
I vote for plan B. Get a trailer. There are two advantages.
1. If something brakes, and it will over time, you have a way of getting the car home.
2. You have a perfect excuse to go buy a new truck
