Can an Eagle 408 hold a 200 shot safely?
Old Apr 4, 2005 | 08:31 PM
osuhunter07's Avatar
Default Can an Eagle 408 hold a 200 shot safely?
Hey I am looking buying a 408 now, and I was wondering if I do the TNT f2 system, a 408 with an Eagle crank and Eagle h beam rods and diamond nitrous pistons with duramoly rings can hold a 200 shot without a problem. I would want to do a progressive two stage system, of coarse it would have a fpss, WOT switch, all the goodies. Also would does anyone have a 246/250 cam in there 408 or does anyone know what cam I should go with? Thanks for the help!
Old Apr 4, 2005 | 09:07 PM
red90cobra's Avatar
yes it will hold it.
Old Apr 4, 2005 | 09:52 PM
Navy David SS's Avatar
If my stock bottom ender can hold 200 shot, your 408 should. I'll put one carification on this -- if you have the after market fuel pump, injectors and a damn good tune.... I would also advise on a good rear-end, suspension and tires.
NO problem
David
Old Apr 4, 2005 | 09:57 PM
I sold my 42 lbs injectors with my blower kit, what should i run now? also will an intank 255 push enough fuel?
Old Apr 4, 2005 | 10:30 PM
Elite_Hot_Rod's Avatar
I run 40 LB SVO injectors on mine for a 300 shot. I think you might run out of fuel with only a 255 supporting it, to close for comfort for me.
Old Apr 4, 2005 | 10:40 PM
what do you think i should do than? what about the racetronix system of the inline and intank?
Old Apr 5, 2005 | 01:04 AM
Robert56's Avatar
Here's the injector formula. [Injector size=bhp x bsfc (usually .5) / No. of injectors x .8 (duty cycle)] So, with your stated 493hp plus 200hp shot = 693 expected hp, You get: 346.5 / 6.4 = 51.14 min injector size for a dry hit, and 246 / 6.4 = 38.51 min injector size for a wet hit or for N/A.
Old Apr 5, 2005 | 07:17 AM
v8maro's Avatar
The eagle can hold 300dp all day long.
Old Apr 6, 2005 | 07:54 PM
Magic Chicken's Avatar
12 Second Truck Club
if it can't, I'll be $4000 in the hole for another shortblock.
Old Apr 7, 2005 | 02:42 PM
Shoulder Shaker's Avatar
I would think that it would hold it. I will find out very soon.
Old Apr 7, 2005 | 06:59 PM
Ben R's Avatar
Eagle rotating kits are rated at 1,500 RWHP, and I believe that. There are countless turbo Mustangs making 1,000RWHP+ with basic Dart blocks, ARP studs, and Eagle rotating assemblies. That Eagle stuff is impossible to beat for what you pay for it.
Too many people buy 347's/382's/383's/408's/427's/434's and just have to have the high-dollar Lunati pieces, but skimp on what really matters, the induction system. If people would spend less on the shortblock and more on the induction system, we'd be seeing a lot more 550RWHP 408's and 600RWHP 427's and 434's
The Lunati stuff is very very good, but unless you plan on building a race-engine, it's simply overkill. A lot of people are aware of the potential balancing problem with the Eagle cranks. They sometimes require a few pieces of heavy-metal to properly balance, and it generally costs $50 per piece of heavy metal, which adds up quickly. If you're worried about that, or if your machine shop would prefer to not take the risk, go buy a Callies crank. They're super strong and and they're a good $$$ middle ground between the Eagle crank and the Lunati crank.
Just one persons opinion...
Old Apr 7, 2005 | 07:03 PM
Jason99T/A's Avatar
I can shift faster than you.
I agree 100%!
Old Apr 7, 2005 | 07:05 PM
viper9403's Avatar
No problem!!!
Old Apr 7, 2005 | 07:33 PM
So Lunati is better than Callies? I thought it was the other way around.
Old Apr 8, 2005 | 12:44 PM
ITLstallion04's Avatar
My motor holds a 250 shot easy. Im quite sure a forged 408 will hold a 200 shot.
Old Apr 8, 2005 | 08:15 PM
Ben R's Avatar
I don't know which one is stronger, but the Callies cost a lot less than the Lunati.
The point is to try to save money on the shortblock (Use Eagle/Callies instead of Lunati) and put the money saved into your cylinder heads.
