Purge Lines?
Old Apr 6, 2005 | 03:20 PM
ctd03's Avatar
Default Purge Lines?
I have a 2000 ws6 and i am going to run two purge lines out the side vents behind the front tires. My question is what should i use for purge lines. I has to be bendable and not to big and it can't just be a rubber hose b/c i will blow that right open? Please help.
Old Apr 6, 2005 | 03:30 PM
Dustin's Avatar
i would like to know whats good too, i have a clear rubber hose thats good for 2000 psi but its so flexible the purge knocks it out of place and it pisses me off.
Old Apr 6, 2005 | 03:31 PM
68maro's Avatar
7 Second Club / STF Veteran
just regular old copper tubing works best.
Old Apr 6, 2005 | 03:46 PM
Green Thunder's Avatar
I used stainless tubing and braised -3 male fittings to them..
Old Apr 6, 2005 | 04:00 PM
Z284U2TRY's Avatar
Ummm how is that going to ket you know all the air is out of the line if you can't see it? But you can go to your local parts store and just use brake line cut and bend to fit.
Old Apr 7, 2005 | 07:51 AM
marlowchris's Avatar
I did mine that way. Copper tubing is the way to go. Brake line is to much trouble to bend. Search for "side cove purge video" and check out my set-up.
Old Apr 7, 2005 | 02:38 PM
-IH8RICE-'s Avatar
I used a some tubing bought at home depot just a clear tube nothing special and routed it out of the scoops on my friends cobra hood. We just clamped it to the copper line coming out of the purge noid and then ran it to where we wanted it.
