Help -- building purge
Old Apr 15, 2005 | 04:06 PM
99BackNBlackZ28's Avatar
Default Help -- building purge
I've got my dry kit mounted, wired, etc, except for my purge.
I searched an am getting conflicting info on which fittings to get, etc.
I have a NOS purge solenoid, from there I dont know what I need. Would like to run 1/8" or 3/16" copper tubing or brake line in a dual purge out the ram air hood. What type of fitting would screw into the N.O.S. solenoid? My solenoid is right by the hood latch, so I would have to run the fitting into the solenoid, followed by some 1/8" or 3/16" tubing into a t-fitting (compression I assume). Then the dual purge....or am I wrong?
Old Apr 15, 2005 | 04:37 PM
David@TNT's Avatar
Get a 1/8x#3 fitting for the inlet and a 1/8x#3T for the outlet.. If you have a flare tool, all you would need is 2 b nuts and collars.. Hope that helps man..
Old Apr 15, 2005 | 07:09 PM
Dustin's Avatar
the 1/8x-3 Fitting, where can you get that, because my line running into the fitting broke off so my purge line wont hook up
