new to nos.here are my mods here are my questions..
ok i have a cammed ls1 with all bolt ons what kind of kit do i want ,to not blow my motor, and do i need a new fuel system and new injectors?!?! i have about 385 to 390 rwhp what will i have with a 150 shot?! wet or dry and how much is a great kit with bottle warmer everthing door install .... ohh ya im on stock rear end soo i probly dont want to juice in first because i cant even hook up now
I'd go with a dry nitrous kit, 100 shot, and with all the safety **** needed, everything usually comes out to around $1,000 give or take. Fuel injectors and pump would be smart. The NOS 5177 kit is good, or Nitrous Outlet's Halo kit is good as well. Check out Nitrous Outlet(link to the right) and I'm sure dave will chim in sooner or later to give you his .02
i had 385 and on a 150 wet shot i got 513.i backed off timing and richened it up for "some" security.fuel pump is a good idea.if you go wet you won't need bigger injectors.theres pros and cons to both so whatever you choose,happy spraying!!!
my two cents. grab a tnt f1 kit. get a fuel pump. bottle heater. and what ever else in excesories you feel like, purge, gauge. fpss. you'll be good for i'd say a 125 shot. long as you don't spray outta the hole.
