Need help with adding a window switch to my system.
Old Apr 21, 2005 | 09:41 AM
delusion's Avatar
Default Need help with adding a window switch to my system.
i have a 5177 NOS kit, with the WOT switch and Fuel Pressure switch. I also have an inline a1000 fuel pump that becomes activated at 2,000 rpms using an MSD rpm activated switch. So it's already hooked up to the rpm source, whatever that is. Anyways, can i use a distributor block to split this RPM source to my window switch? and how about the 12v, can i splice into that as well? thanks.
Old Apr 22, 2005 | 02:09 PM
delusion's Avatar
anyone? what would be the best way to splice into the wires? and is it gonna cripple the performance of either unit.
Old Apr 22, 2005 | 02:14 PM
zrated's Avatar
I used tap connectors I got at radioshack. Worked good for me
Old Apr 22, 2005 | 02:15 PM
zrated's Avatar
Here you go here
Old Apr 22, 2005 | 03:10 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Ok, do not use a scotch lock they have been none to come loose. Just strip a little insulation away from were you wnat to connect and splice your wire in.
Here is the drawing for connection. and the 12 volt soure can come from you arming switch the micro switch.
Hope this helps.
Ricky
Old Apr 22, 2005 | 06:13 PM
delusion's Avatar
any idea on the gauge of the wires?
Old Apr 22, 2005 | 11:29 PM
Robert56's Avatar
I have two msd switches one window and one activation off the same tach wire, no problemos. Used the same 12v wire also.
