Carb plate to EFI conversion.
The Super Pro shot Noids are supposed to be good for 200hp.
If I understand correctly from lurking here on the boards If I deleted the fuel noid and injected the NO2 upstream of the MAF that would be a dry system where the MAF would compensate for the intake charge of N02 by adding more fuel?
What are the limits of this type of setup at what point can the MAF no longer compensate?
I have expirance using a plate system on a carb setup however I am having a hard time thinking out the concept of the Wet system in a EFI system. Does the Fuel/NOS mixture injected into the intake manifold?
Thats enough questions for now I am sure your responses will generate more questions. Thanks in advance for helping a EFI newbie.
I am going to guess that you tap into the fuel rails?
What about fuel pressure is it high enough at the rail not to drop and lean out while having to feed both the fuel noid and 8 hungry injectors?
What about a dedicated fuel system to feed the NO2 system the pump could be wired to come on when the N02 system is armed?
I have a small fuel cell and a Paxton Kamakazie fuel pump and lots of braided fuel line left over from another project that I could you to fab up a dedicated fuel system to feed the NO2 system the pump could be wired to come on when the N02 system is armed am I outsmarting myself here?
What about timing how would you "Tune" the engine to take timing out on the spray are there aftermarket controllers or would I have to buy and learn to use some sort of editing program for my ECU.
Sorry If am rambling but I am still learning the joys of EFI. Once again thank you very much for you time and advice.
Thats enough questions for now I am sure your responses will generate more questions. Thanks in advance for helping a EFI newbie. [/QUOTE]
If I want to go higher then 100hp dry I will have upgrade my injectors and retune the ECU? Are the injector plug and play will the ECU read that it has bigger injectors or would the ECU have to be reprogramed?
