? on installing fuel pressure sensor.
Old Apr 24, 2005 | 06:27 AM
tektrans's Avatar
Default ? on installing fuel pressure sensor.
I saw an inline fitting for the sensor in Jegs. My question is how do I secure the braided line to the fitting once it's cut?
Old Apr 24, 2005 | 07:27 AM
GM Muscle's Avatar
You don't cut the braided line. You need a peice of -4AN line with fittings on both ends. Basicly, you'd take your current fuel line off the rail, screw the manifold for the pressure sensor on to the end of the rail, then re attach your fuel line to that.
Here's a pic of mine to help you understand.
Old Apr 25, 2005 | 01:43 PM
tektrans's Avatar
Great Pic. Nice neat install. Mine is a DP system so It won't work off the rail like yours since it's a separate fuel supply but I get the jist of it. Thanks again for your detailed pic.
Old Apr 25, 2005 | 01:49 PM
GM Muscle's Avatar
Ahh, it makes alot more sense now. Did you want to put it at the noid? You could just pick up a female AN coupler and a male/male fitting for the other side so you can run it inline or Summit must have some kind of hose end combo that will work. Does your FP regulator have a pressure port on it that you can put the sensor on.
