NOS Questions
Old Apr 26, 2005 | 11:03 PM
Ls1LikeNoOther's Avatar
Default NOS Questions
Ok so I have a 383 LT1 with scat crank/eagle rods/diamond pistons/lazer camshaft/comp cams valvetrain stuff/ported heads/fuel system/throttle body/full bolt ons...Also I drive the car EVERY DAY,like rain shine everyday the car gets drivin..
Im wondering how much nitrous is going overboard on this for a daily driver...The car already goes into the low 11's with a 2.0 sixty foot but I want more..I almost am tempted to go for a direct port fogger kit,but im looking for some opinions..Maybe just a basic wet kit? Need some input..
Old Apr 26, 2005 | 11:51 PM
Elite_Hot_Rod's Avatar
Well with the forged internals you should be able to handle a fairly large shot, I'd say somewhere between 200 and 300 will be safe. Question, do you not have headers, they're not listed in your sig? Also you'd definitely benefit from a lower 60ft time, do you have any suspension mods?
Old Apr 26, 2005 | 11:54 PM
RedHatRdRacer's Avatar
I drive mine everyday and wouldnt be scared to tap the button on a 300hp shot even though all i have ever ran was 150 but its doing the job
Old Apr 27, 2005 | 10:41 AM
I have a 12 bolt with a 3.73 gear(wanted bigger but again street everyday)hooker LT's,ALston Adj torque arm,and sfc's...no control arms though..60's lacking bc I was on a bald nitto...I should be able to cut a lower 60' with my new tires now..
Old Apr 27, 2005 | 11:45 AM
NXJeremy's Avatar
I just sold my TA that was basically the same set up you are running. The motor and 12 bolt should handle 300hp without problems. What tranny are you using, converter?
Old Apr 27, 2005 | 01:41 PM
6 speed.
Old Apr 27, 2005 | 01:47 PM
NXJeremy's Avatar
You should be ok, I would suggest upgrading the clutch if you haven't already though
