Anyone try Iridium + nitrous...
Old May 4, 2005 | 07:19 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
King, as you know, we use the TR6IX in our Camaro/nos and Autolite 3910 in our BBC w/200 nos.
Originally Posted by KingCrapBox
Autolite AR3935 for a 'Street Car' with a small shot, or an Autolite AR3932 for a 'Race Car' with a big shot.
By far the best nitrous plug you can buy.
Old May 4, 2005 | 11:35 PM
Green Thunder's Avatar
Originally Posted by rez-t/a
I run TR55s with a 100 shot. and the do fine.
TR55's? Not sure I would use them with nitrous.. I would go to the 6's if I were you..
Old May 5, 2005 | 11:04 AM
02 Pewter LS1's Avatar
I just talked to NGK and they said that the iridium plugs are great to run with nitrous. He said they would hold up better and last longer than the old reliable TR6 that we use. He also said that the newer style motors LS1 and modular ones seem to run much better with these new plugs.
I have a set of TR7ix plugs which is one step colder than the TR6ix. I wonder if that is to cold for up to a 150 shot of nitrous? I run a 100 at the present time but will be moving up to the 150. The guy at NGK said they would be fine for the 150 but how will the car be NA will it be rich as hell? Maybe I should bring these back for the TR6ix?
Old May 5, 2005 | 11:49 AM
Ben R's Avatar
I'm not against the NGK plugs or anything. They're good plugs. But if you're looking to make some REAL power (AKA your BBC setup) then Autolite is the way to go.
But for somebody to say they don't work in GM's is just foolish...
Old May 5, 2005 | 02:28 PM
ls1_doc's Avatar
But Autolites in a Ford work wonderfully?
You'll have to explain that to me...
Yeah im not sure why that is but i have seen more probelms with bad running cars and all it was were cheap spark plugs in a new chevy
Old May 5, 2005 | 03:38 PM
Mike TexaSS's Avatar
8 Sec Tuner
Autolite plugs are in almost EVERY big power car out there. From Outlaw 10.5, to Pro-Stock, Top Sportsman, Comp Eliminator, Pro-Modified, Pro 5.0, and even NASCAR.
Autolite plugs are not 'cheap spark plugs'.
-KingCrapBox
Old May 5, 2005 | 07:08 PM
11 & 7 Second Clubs
Autolite 3910 is a favorite amongst Pro Stock and CE racers. But at $2.25/ea., people often look for other plugs.
-KingCrapBox
