Purge Problem
Old May 5, 2005 | 12:18 PM
99Ws6TransAm's Avatar
Default Purge Problem
I got my bottle filled for the 1st time yesterday..put it in..opened up..checked for leaks..all seemed good. I went to purge it..and it didnt come outta my purge line... i was confused..so i did it again...same thing..heard it..but didnt see it..
When i hit the purge button..it is coming outta my shark nozzle...its like its completly bypassing the purge solenoid.
Is the connection to the button the problem? Did somethign maybe get crossed when i wired it? cuz its just opening the nitrous solenoid...no fuel..just nitrous. The arming switch is not on when im doing this.
All my switches are wired together..threw ground and power and such..that maybe the problem?
Old May 5, 2005 | 12:49 PM
Stroker 1500's Avatar
you have it wired wrong
Old May 5, 2005 | 02:19 PM
NXJeremy's Avatar
Definately sounds like a wiring issue. I would find a diagram of the correct wiring and retrace everything.
Old May 6, 2005 | 08:27 AM
Yep figured it out late last night..wire was crossed from the purge to the fuel..instead of fuel to nitrous. Fixed that..hit the switch and it worked...sweet!!!
