Max jetting for single nozzle?
Old May 8, 2005 | 12:00 PM
Gold Phoenix's Avatar
Default Max jetting for single nozzle?
I have a NitrousWork Single Wet System that can be jetted to 175HP. Does anyone think I can try for 200 or even 250 with larger jets? Of course, I have the motor and fuel system for it. Or do you think the nozzle or soleniods can't flow that much?
Old May 8, 2005 | 02:17 PM
necrocannibal's Avatar
I dont know about their nozzles but the TNT nozzles can flow that. Im spraying a 200 shot through a single nozzle and their Power Ring.
Old May 8, 2005 | 03:18 PM
stik6shift93's Avatar
I used to have a nitrous works kit on my car a while ago, if they still come with the same solenoids that came with mine you won't be able to go above 175 because they can't flow anymore than that.
Old May 9, 2005 | 01:03 AM
That is what I figured. Thanks.
Old May 9, 2005 | 02:04 AM
Formula_Power's Avatar
you can take the nitrous jet out and you will only flow 175....it is not based on the jet rather then the soloniod....you will have to upgrade the "noid" to get more hp
Old May 9, 2005 | 03:23 AM
At that point, I would add a second stage. But I don't want to since I am getting off the bottle after this.
Old May 9, 2005 | 09:07 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
I would recomend you ask the company that built it.
Ricky
