What pressure is everyone spraying there wet kit at...?
What pressure is everyone spraying at...? I spray at 950 to 1000. Talked to my filler today and he sprays at 1100-1150....?
Just seeing where people are at?
Paul
Paul
Originally Posted by Robert56
1070psi here, dry though.
Originally Posted by NXJeremy
Robert- I don't ever deal with dry systems and was wondering about the bottle pressure's effect on them. Is there any issues with the car going rich if the pressure is too low (850-900psi)?
One more thing to note for wet guys. If you raise your bottle pressure above the manufacture's psi, you've upsized your n2o jet through the added press, so your a/f will be lean. this works great for dry guys as according to track conditions if your dial in time is off bump up the press for added hp. wet you can do also, but more difficult to get a/f correct with also upsizing fuel jet. you can do a spread sheet ahead of time though.
