Medical Grade Nitrous
Old May 14, 2005 | 09:17 PM
redaddiction's Avatar
Default Medical Grade Nitrous
My *friend* has access to medical grade nitrous is there any benefit to this ? It would be use on a 423 ls1.
Old May 14, 2005 | 09:25 PM
GM Muscle's Avatar
Nope, it should be the same purity and nitrous+ with sulfer dioxide. I remember reading a side by side test on this subject, the medical came in at like 97% pure and the + at 98% or something around those numbers.
Old May 14, 2005 | 09:53 PM
I think the only down side to the sulfer though is it clogs lines over time.
Old May 15, 2005 | 12:04 AM
Elite_Hot_Rod's Avatar
I disagree with you 100%. The sulpher is added in to keep people from inhaling the gas, that same sulpher goes into your noids and and jetts and can seperate and clogg them. Check your plugs sometime after you run it thru the system, the sulpher turns the electrode ring green. If you have access to medical grade N20 I'd use it and do. How can anything with additives be as close to 100% pure as something without them?
Old May 15, 2005 | 08:21 AM
860 Performance's Avatar
Ther is NO advantage.
There is only a maximum of 100 parts per million, thats .001% sulfer dioxide maximum. I have used both and definetly can not tell the difference. Why would you think that small ammount of sulfer could possibly clog a jet? Have you seen that or are you speculating?
Old May 15, 2005 | 12:58 PM
Chicago Z06's Avatar
Sulfer IS corrosive and over time will create cloggs due to it corroding the screens in the fittings with possibly pieces breaking loose and hanging a solenoid open... for anyone who have sprayed 20+ bottles of nytrous plus pull your feed fitting and i'll bet there will be signs of corrosion... the older the install the more likely hood of clogging. and yes i have seen it first hand..
Old May 15, 2005 | 01:23 PM
Huh, I have sprayed over 20 bottles, what does it look like? I'll go take a look.
Old May 18, 2005 | 12:22 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
The amount of sulfur in the Nitrous Plus is so small that the corrision side of things does not matter. The greening on a plug I have only seen that with a antifreeze leak. The coloration on a plug is mainly driven by the fuel and what is in it. Additives detergents, water etc. Medical grade and Nitrous Plus perform the same. The clogging of jet again not real likely in our life time but if your nitrous is extremly dirty and you do not use a filter you deserve to have something bad happen to you. You did not take the precaution to stop it.
One thing that everyone seems to miss. You and your freind get caught with medical grade you will be in big trouble. Pure nitrous is a controlled substance and you have to have a licence to handle it. A medical licence. So use it or not the results are going to be the same.
Ricky
Old May 18, 2005 | 05:45 PM
GM Muscle's Avatar
I just checked the lines and fittings on my refill station when switching bottles today. No signs of corrosion that I can see. The set up is 6 years old.
Old May 18, 2005 | 07:29 PM
I checked mine too, just to amuse myself, clean as a whistle.
Old May 19, 2005 | 12:32 AM
stngh8r's Avatar
i would suspect the only advantage would be if you can get it cheaper?
Old May 19, 2005 | 05:46 PM
Phoenix 5.7's Avatar
a few ppl around here run medical grade, they think it is better. that could be complete speculation. they are also much older, so the early street nitrous could have been much worse quality than the currently available stuff.
Old May 19, 2005 | 09:00 PM
TigerWoodsJr's Avatar
I would have two bottles, one medical and one for the car... $5 bayloon... sorry, got offered it a few times in daytona, lol.
Old May 19, 2005 | 10:40 PM
Ricky even though it is a controlled substance do you really think the police are going to test it to determine if it's medical grade or not? I seriously doubt it. If I can get the medical grade N20 I'm going to use it before the nytrous stuff.
Ricky
Old May 20, 2005 | 12:28 AM
Robert56's Avatar
No the early n2o users could get medical grade only, and it was easy to get. Then it caught on as a way to get high, so they added the sulfur and made the clean stuff controlled. that's were the giggle gas comes from, gettin high. When I was younger, we allways joked about putting a spigot in the dash to access the bottle. probably not a good idea, spraying motor and nose at same time.
Old May 20, 2005 | 08:44 AM
NXRICKY's Avatar
No the police will not test anything. What will happen is you will till a freind, that freind tells someone, so on and so on, and sooner or later it lands on some bleeding hart policy maker and the **** start rolling down hill. Think of like any secret, the only way to keep one is not to try showing off and telling the world about it.
I know it sucks there are always poeple sticking the nose in other people business it happen. Exp. I was pulled over in the camaro about 12 years back, just becuase I did have any cats on the car. Now how did the cop know that. And its Nitrous PLUS or (+) not nitrour stuff. Good luck use what you want, car will run the same.
Ricky
Old May 20, 2005 | 08:45 AM
NXRICKY's Avatar
Now thats just wrong. " hey are we going any fast WEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE"
Ricky
Old May 20, 2005 | 11:05 AM
David@TNT's Avatar
It is much cheaper actually.. Your paying for the added cost of bonding the sulfer with the nitrous due to the process.. I dont belive there is any legislation as of yet on selling pure nitrous, as long as you 18 years of age and dont use it for "huffing".. The reason why gas places dont sell it is the sheer liability factor.. You can imagine what would happen if they sold a bottle of it to somone that passed out behind the wheel using "balloons"..
Old Jul 1, 2006 | 09:02 PM
FireSilverLullaby's Avatar
Is it at all illegal to sell automotive grade nitrous, and do you need a medical licence to get medical grade?
Old Jul 3, 2006 | 08:49 PM
1999 SS's Avatar
you do not need a permit or liscense to get automotive/industrial grade nitrous but you do need a permit to get medical grade nitrous. medical grade is regulated like anyother perscription drug.
all nitrous starts out as medical grade but when automotive/industrial bottles are filled at the distribution facility their is an additional line connected to the fill hose with either a valve or little red button that releases the sulphur into the fill stream.
the absolute only reason sulphur is added to to keap people from huffing the gas to get high and there is only supposed to be 100 parts per million but thats not always true.
till recently (about 2 years) medical grade would be sold intermixed with auto grade unintentionally but the FDA has been busting ***** so it doesnt really happen anymore.
