an sizing
Old May 18, 2005 | 04:36 PM
ls1_doc's Avatar
Default an sizing
i have a nx wet kit how do i know what an sizes i need for a purge solinoid?
Old May 18, 2005 | 04:44 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Will your purge valve connect using a 1/8 npt x 1/8 npt union. And the outlet or the purge valve is a 3/16 compression. The hard line used is 3/16. The AN line that is comparable would be -3.
Ricky
Old May 18, 2005 | 04:46 PM
Nitro Dave's Nitrous Outlet's Avatar
If you have a NX kit you really do not need to wory about the an size.The solenoid will go straight into the side of the nitrous solenoid.However it comes with -4an lines.
You will need a part number 15600.
Dave
Old May 18, 2005 | 05:46 PM
ls1_doc's Avatar
thanx guys.....same thing with a bottle gauge? and what is the diiference with the manifold and gauge and just the gauge?
