First hit on the juice
Old May 22, 2005 | 04:23 PM
ws6sojuiced01's Avatar
Default First hit on the juice
First hit on the juice last night and i about **** my self. I need tires bad at a 35mph or so kick i could not get it to stop spinning i was all over the place and nearly lost it. How many of you guys have a popping sound in the exhaust after coming off the pedal.
Old May 22, 2005 | 04:38 PM
tonyt123blue's Avatar
i do if i let out before the window switch cuts it off.
Old May 22, 2005 | 05:08 PM
Robert56's Avatar
Wet kits will do that when snapping throttle shut from wot. Try progressively letting off and rpm's will clear it out and no problem. If you go past the ws high rpm mark the continued rpm clears out the remaining mix, and thus no popping. A bigger hit can be a problem when this happens, so just take it easy on deceleration.
