Air in lines
Old May 31, 2005 | 10:53 AM
BadAssFast's Avatar
Default Air in lines
I don't know that there is an exact answer to this but...this past weekend is my first using a purge valve...i noticed about 1-2 sec of "air" before N20 cloud between my first and second tune runs which were about 5 min apart. I guess I expected to get a N20 cloud immediately. My perfromance seems great and no apparent leaks anywhere...
Old May 31, 2005 | 12:06 PM
slowec's Avatar
Thats why you purge!
Old May 31, 2005 | 01:03 PM
BadAssFast's Avatar
I know...its the quantity of air i'm refering too...i'll add in the past things were sooo unpredictable - no longer!!!
Old Jun 1, 2005 | 04:54 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
If its real hot where your at the liquid nitrous in the main lines may be turning to a gas.......
Another possability is that your nitrous noid may be partially clogged making it take longer to purge the air out. Is performance down a bit?
www.DynoTuneNitrous.com
Cheers
Dan
Old Jun 1, 2005 | 09:14 AM
BadAssFast's Avatar
Cheers
Dan
Performance is spectacular. The only true test for perfromance will be on the dyno coming up when time permits. I'm pretty careful to cap lines when bottle is out...anything is possible. All this is probably normal...i'll keep my eye on things for sure.
