Master Blaster Purge System?
Old Jun 10, 2005 | 10:53 AM
setxws6's Avatar
Default Master Blaster Purge System?
Does anyone have, or know someone that does, the Master Blaster purge from Dynotune? What does it do over there regular purge? It looks huge. Also, is Dynotunes purges pretty reliable? Thanks.
Old Jun 10, 2005 | 11:29 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
The MasterBlaster purge uses a 250HP solonoid versus our regular purge which uses a 175HP Solonoid. Our solonoids are top quality and our customer service cannot be beat. This purge is louder and huge!
http://www.dynotunenitrous.com/store...p?idproduct=45
Dean
Old Jun 10, 2005 | 01:30 PM
setxws6's Avatar
So basically your just shooting more nitrous into the atmoshere? I think I will probably just get the standard purge. If anyone has any pics of videos of the Masterblaster, I'd like to see them.
Old Jun 11, 2005 | 01:45 AM
setxws6's Avatar
Josh, from watching your purge compared to others with a regular purge, how is it different....as in worth getting? To me it seems you would waste more nitrous because of the bigger noid.
Old Jun 11, 2005 | 07:14 AM
koolrayz's Avatar
I have the regular dynotune purge on my new setup and its great
Old Jun 11, 2005 | 12:30 PM
150shotWS6's Avatar
You should make a vid. so people can see what its all about!
Old Jun 11, 2005 | 01:36 PM
SupahRich's Avatar
That's what I was thinking I have one sitting in my room right now waiting to be installed. Once it's in I'll definately get some video clips of it. I spent a couple of months browsing posts about this setup and was never able to find a sound or video clip of it.
Old Jun 12, 2005 | 02:09 PM
LS1TECH Sponsor
Default DynoTune Purge video
Here is a video of the standard dynpotune purge kit in action. http://www.dynotunenitrous.com/store...ette_purge.wmv
Your welcome to go to the webpage at www.dynotunenitrous.com and checkout all the purge kits.
Cheers
Dan
Old Jun 12, 2005 | 02:12 PM
zrated's Avatar
If the standard purge is on the vette I'm pretty eager to see a clip with the master blaster purge
Old Jun 13, 2005 | 10:20 AM
150shotWS6's Avatar
Cheers
Dan
It really looks like that(probably a cold day)! Damn Cant wait to see the master!
Old Jun 13, 2005 | 02:38 PM
Shinsetsu's Avatar
Cheers
Dan
umm if this is the one I am thinking of, why can't it be used with the "V" purge nozzle? would it work with the Twin Outlet Purge kit ?
Old Jun 13, 2005 | 08:47 PM
LS1TECH Sponsor
It will work with the twin outlet purge upgrade. You can use the "V" Purge Nozzle but you would need to use a braided line or similar to attach to the nozzle.
Dean
Old Jun 13, 2005 | 09:28 PM
Jake the SSnake's Avatar
I used the master blaster purge with the v nozzle and the plastic line lasted about 2 purges. I then upgraded to braided line and drilled out the outlet holes of the v nozzle (so it would flow better) just drilling the nozzle out made a huge difference in the size of the v
Old Jun 14, 2005 | 07:21 AM
Noyzee's Avatar
8 second mod
I have Both. i use the smaller one in cold weather and the Masterblaster in hot weather. reason being in the hot, i get bottle psi down faster, and the smaller one in cold weather because i have no bottle heater i rely on my hot box and a torch.
both are great kits. Mix Dynotune purge with a dynotune psi gauge, and it looks sick!!!
I will try to get a pic of how i did mine.
the dyno tune parts are very nice.
Oh yhea, with the master blaster, It is a head turner!!!!!!! its loud!!
Old Jun 14, 2005 | 08:30 AM
NickcZ28's Avatar
Wouldnt thisa just waste a lot of Nitrous???click
Old Jun 14, 2005 | 09:06 AM
Noyzee's Avatar
8 second mod
not realy, you can just touch the botton quick, and it lets out a little bit.
but say its 95* out, and Bottle press is 1200psi. you get to the line and have to purge to 950 psi. with a small purge it take for ever, with the master blaster you can get to your desired psi faster. no matter what if your at 1200 and have to get to 950 the Nitrous waist will be the same no matter how big the purge.
some people purge to look cool, but the biggest thing a purge is for is to ge the bottle to your disired pressure.
Old Jun 15, 2005 | 04:03 PM
Noyzee's Avatar
8 second mod
Old Jun 15, 2005 | 04:45 PM
setxws6's Avatar
I've never heard of using your purge to lower the PSI.
Old Jun 15, 2005 | 04:54 PM
BIG_MIKE2005's Avatar
thats what its really for. a lot of people just use it for show & intimidation though.
Old Jun 16, 2005 | 03:20 AM
setxws6's Avatar
So you're saying purging is to mainly get your PSI lower before you spray? I thought the main purpose was to get the line full and ready to spray.
