Pill size help!
Old Jun 11, 2005 | 03:19 PM
Dustin's Avatar
Question Pill size help!
I have a 5177 kit and of the 2 lines running to the lid one of them broke a few months ago so I only have one line running to the lid. If i wanted to use a 125 shot what pill size would I need since I am only using 1? Also since it is a 100 shot and I am not running 2 lines anymore does that make it a 50 shot? I have noticed it is much slower with just the 1 spraying? Someone help this newb to nitrous, lol.
Old Jun 11, 2005 | 04:23 PM
Dustin's Avatar
NV got a 61
Old Jun 11, 2005 | 07:53 PM
Robert56's Avatar
Yea, one line is half the output. A NOS rated 100hp shot is really about 85hp at the rear wheels. So, a single 61 is close to a 150hp at the rear wheels. This is because you can't just add the two together and go single, the math doesn't work that way.
Here's the math:
.71(com den) x size of one jet x 2 = single jet size
so,
.71 x 33 x 2 = 46.86 single jet or .047 jet equals a 100hp shot
You probably wonder why a 33 instead of a .032 jet. It's vcause a true 100hp at crank the way NOS does it is dual .033's not dual .032's.
Old Jun 11, 2005 | 08:34 PM
Dustin's Avatar
O ****, so your telling me I am now running a single 150 shot?? Thats crazy, my car is almost stock, wont this be too much for my internals to handle? Its a single 61 by the way..
Old Jun 11, 2005 | 09:38 PM
Robert56's Avatar
It's not that your car can't handle it, you'll run out of injectors and probably close on pump, and lean that way is not good.
Old Jun 11, 2005 | 10:38 PM
Dustin's Avatar
Thanks for the info. I have been told by the tuner that i am already running 110% on my stock injectors with the 100 shot so I will definitely need bigger injectors, and a new fuel pump. Thanks guys.
