Nitrous bumper drag.
i have a question, does that make your 60' a little slower because you crossed the 60' mark still on just the back tires, so the front ones were already past it when it got your rear tires?
Yes the 60ft shows slower. In all reality it really is slower to begin with because the energy that you exerted going up could have been used to go foward. But 1.30 60ft on the rear tires is good and 1.27 is the best but when we set the suspension up next time it will be all foward energy.
wow after seeing **** like that i think im buying some kinda wheelie bars just as soon as i am pullng the tires 12 inches off the ground... i really really dont want to do that and not be able to see nuthing... next thing i know it comes back down pointing towards the wall knowing my damn luck..
No the car has Wolfe Racecraft thru the floor sub frame connectors which are pretty stout and somewhat protect the bottom of the car. The D/S header hangs at the lowest point and that's what it came down on.
Originally Posted by Robert56
What a freaking ride. Do you have the under body frame gaurds?
But just bearly dented it. The primary is far from flat. LOL
The car is now so low we are putting Madman protectors on the car. They will sit about 1in from the ground at most. LOL
The car looks sick. I will post pics when I get the suspension all squared away.
Originally Posted by Navy David SS
Nice picture. It was cool to see. Didn't know what it was like until I recently did the same damn thing. I wasn't as luck on damage. Hope to see you at Thunder this year. -- side note: We need to convince the board rules committe to allow wheelie bars on our slow *** cars.
David
David
V6 Bird
I guess we need a suspension expert to help. I have all the adjustables on the car. What settings would you suggest. 3 up front; 6 out back on QA1.
David
David
You want to motivate the car forward more then up.
Mike
Eric, the SS hasn't really been touched since the engine was pulled and the car put back into the trailer. It looks worse than expected. Even the valves are totally f**ked up
Plans right now are wheelies bars and limiters.
David
Plans right now are wheelies bars and limiters.David
