Few quick questions...
Old Jun 14, 2005 | 12:18 PM
slowprocess's Avatar
Default Few quick questions...
On my quest for 11s, I decided nitrous was the route for me. I'm running a basic nx wet kit with zex warmer and msd window switch.
Just a few quick questions...
1. Do I need to run a relay with my bottle warmer or can I just basically hard wire it with a inline fuse?
2. MSD window switch- cut the two loops to put it into 4 cyl mode...correct?
That's my two questions for right now. I'm sure there will be more on the way. The kit is wired up, but didn't activate the first time. I figure it was because of the msd(I hadn't heard about the wire cutting until yesterday).
Thanks guys.
Old Jun 14, 2005 | 03:46 PM
fastazztruck's Avatar
i will answer. yep you can. and yep you do. but i am sure you want others to answer as well.
Old Jun 15, 2005 | 09:12 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Thanks guys.
You know I looked at there site and could not find any info on the heater. Needing a relay depends on the amount of amps that thing draws..
Buy the one that is set up for the square stuff. Have them in stock on the trailers. Or get the FJO unit.
Ricky
