BMN rpm nitrous switch
Old Jun 14, 2005 | 11:53 PM
Y2kforgedSS's Avatar
Arrow BMN rpm nitrous switch
http://www.nitrousoutlet.com/outlet/...section_id=105
Will yall tell me exactly what all this does, i have read it where it shows the details but im wondering if i have to buy the pills for this kit, i also would like to know what the first gear lock-out is and the shift light output is?
Thanx for input
josh
Old Jun 15, 2005 | 02:59 AM
ChrisLe's Avatar
Thanx for input
josh
I have the BMN switch and absolutely love it. You do not need pills as the rpm's are adjusted electronically. First gear lockout is designed to prevent the Nitrous from activating in 1st gear on a manual tranny. It does this by not activating the Nitrous system until after you've reached the upper (turn off) rpm limit that you set on your window switch. So, for example, if you go WOT in first and shift into second after your rpm's exceed the window switch’s upper rpm limit, the nitrous will spray in second and subsequent gears.....The only problem with the lockout feature is if you 'short shift' first as you will not spray in second or any subsequent gear until you exceed that upper rpm limit before shifting..
The shift light output is designed to trigger an aftermarket shift light (or a relay) at the upper rpm limit you set on the BMN.....I believe it can handle a max of .6 amps.
Old Jun 15, 2005 | 09:05 AM
Nitro Dave's Nitrous Outlet's Avatar
Chrisle,
Good job describing this unit.
Im just going to add that the switch does not use plug in modules.It has turn *****.
Dave
Old Jun 15, 2005 | 11:01 AM
Cool now i have made my mind up on what i want and thats it right there!
josh
Old Jun 16, 2005 | 02:40 AM
ChrisLe's Avatar
josh
Good chioce. I'll add that wiring it up is idiot proof as there are LED's that, when you test the unit, will indicate whether or not its wired correctly....
Old Jun 16, 2005 | 10:27 AM
1ScrudeDude's Avatar
This will help me greatly. That alone just confirms I will be getting this
Old Jun 16, 2005 | 11:53 AM
Awsome cause im at home right now wainting on that to come in, this is my first nirtous kit at the age of 19 and im doing damn well so far all i have left is running the hoses from the bottle to the front then when that comes in.
josh
Old Jun 16, 2005 | 04:42 PM
WhatCam?'s Avatar
what about auto cars? work with any year model?
Old Jun 16, 2005 | 05:23 PM
mikey94_95's Avatar
Yes, it will work with an automatic.
