major ZEX kit problem
Old Jun 17, 2005 | 01:32 PM
94camarof1's Avatar
Default major ZEX kit problem
just got my dry kit installed on my LT1 and got the bottle filled yesterday. Last night I tried it out, and when the nitrous is injected, the car basicly just starts sputtering and you can feel the nitrous working, and then stopping... just surging and not having a constant flow. I also hit it from a stop once... and the car backfired really bad, and my service engine soon light came on right away... I thought I was without a motor, but it's still running fine but now I'm afraid to try it again. My intake duct elbow is ripped a little on the bottom... that's the only thing I know that's wrong with the car itself...
Old Jun 17, 2005 | 03:54 PM
daryl2cb@yahoo.com's Avatar
What type of plugs are you using? I am not sure about the LT, but in the LS1 you need a copper plug in the Ngk tr6 range, also gapping the plug is important. Also if you have one, check your fuel pressure safty switch, it might need a little adjustment.
Old Jun 17, 2005 | 04:58 PM
94camarof1's Avatar
would bad plugs cause it to run so bad under spray?
And don't think I have a fuel pressure safety switch
Old Jun 17, 2005 | 05:20 PM
01FbTaWs6's Avatar
if you dont have a colder plug, it would have somethign to do with it, for the lt1, you definatelly wanna get a colder plug, also your optispark ignition could be shitting out too.
Old Jun 17, 2005 | 05:44 PM
94camarof1's Avatar
I'm 99% sure the previous owner put in nitrous plugs when I had the old NOS kit on it
Meaning have to put in a new optispark?
Old Jun 17, 2005 | 05:52 PM
Magic Chicken's Avatar
12 Second Truck Club
should've kept the NOS kit. a new set of plugs is cheap. if you don't have a fuel pressure safety switch (fpss) you NEED one.
Old Jun 17, 2005 | 06:13 PM
Clipper's Avatar
doesn't the Zex "module" contain a FPSS?
Old Jun 17, 2005 | 11:56 PM
94camarof1's Avatar
NOS kit before this was doing same thing... so I thought it was a problem with the kit itself, but it must not have been.
plugs are cheap, but not fun to install
everybody really think's its plugs on a car with 30k miles... and like I said I'm pretty sure the plugs have been changed for nitrous
 Michael S. Palmer
Old Jun 18, 2005 | 12:39 AM
Robert56's Avatar
Hows your fuel pressure/system. Spiking it right?
Old Jun 18, 2005 | 05:19 PM
94camarof1's Avatar
I have the supplied ZEX booster fuel system.... what do you mean by spiking?
Old Jun 18, 2005 | 10:15 PM
Robert56's Avatar
That's it.
Old Jun 19, 2005 | 04:53 AM
Stroker 1500's Avatar
sounds like a bigger problem than plugs to me.. What rpm are you spraying at? are you trying to spray with that hole in the intake tube? have you checked for proper fuel delivry? Maybe your pump isn't strong enough, but it definately sounds like something more than plugs
Old Jun 19, 2005 | 11:54 AM
94camarof1's Avatar
I thought it sounded much more serious than plugs also, espically how it just backfired so bad when I was at a stop using it. I have been spraying with the cracks in the intake elbow, but just ordered a new 1LE elbow. That would be nice if that was the problem, but I wouldn't think it would be since the car runs fine w/o spray. How can I check for proper fuel delievery. I guess I thought the system would be fine with a fuel pump booster. There's something that I've noticed since adding that though that seems a little strange, whenever I rev at night after the RPM's drop back down, blue flame comes shooting out both sides of the exhaust?
Old Jun 20, 2005 | 12:44 AM
94camarof1's Avatar
wow, found the problem for sure I think
I took out 3 plugs... 2 of them completely had their tips broke off, I don't even see how they were getting spark! And they ended up being the stock plugs... previous owner lied to me about having nitrous plugs in it...
Old Jun 21, 2005 | 12:36 PM
94camarof1's Avatar
Old Jun 21, 2005 | 03:51 PM
TNTramair's Avatar
LOL...geeee, ya think that might have something to so with it??!?!?! i would have guessed the same thing...but more so the nitrous was just blowing you plugs out...never thought they'd be that bad.
Old Jun 21, 2005 | 03:56 PM
1ScrudeDude's Avatar
Those plugs got
Old Jun 21, 2005 | 04:07 PM
94camarof1's Avatar
almost funny
Old Jun 22, 2005 | 08:53 AM
TNTramair's Avatar
Originally Posted by 94camarof1
almost funny
im sorry...wasnt tryin to be rude. but you have to see it this way...you could've seriously destroyed your engine over a set of $20.00 plugs. and you didnt, so you have to laugh it now.
Old Jun 22, 2005 | 01:22 PM
94camarof1's Avatar
Yup, I understood what you said.... I was saying it's almost funny that I was that close to destroying an engine but ended up just having to replace plugs.
Got the new plugs today... thanks for everybody's help.
