Corvette TPS and Window switch wiring help!
Old Jun 30, 2005 | 05:52 PM
Airwolf's Avatar
Originally Posted by TT_Vert
how did you guys do the 1st gear override?
D
ave
You would need to install a Normally Closed cherry switch on a bracket and mount it to the shifter, coming in contact with the shifter in 1st gear. I was going to do this but spraying a 100 shot at the track off the line is badass! Anyhting larger you my want the switch or go progressive controller.
Old Jun 30, 2005 | 11:16 PM
NOTFAST's Avatar
Originally Posted by BonerBen
It works! 75 shot felt awesome, now time for the 100 jets
now will you be up for running the silver z06?
Old Jul 1, 2005 | 09:17 AM
TT_Vert's Avatar
got any pics of how to mount this switch? Not much room on a c5 near shifter base.
dav
Old Jul 1, 2005 | 03:57 PM
Airwolf's Avatar
dav
I have a pic somewhere on the home computer... I will find it and post.
Old Jul 18, 2005 | 12:19 PM
XTrooper's Avatar
Originally Posted by Airwolf
With TPS
http://www.airassault.net/z06/nos%20...20override.xls
With WOT Switch
http://www.airassault.net/z06/nos%20...ll%20gears.xls
TPS is a pain in the ***. Never got mine to work right. Use a switch under the pedal. The diagram above shows the wiring and the correct pin off the ECU.
Airwolf,
In your diagram, which is very nice, what do the boxes marked "coil" refer to? Thanks!
Old Aug 31, 2005 | 12:24 PM
mustgofasster's Avatar
first gear lock out is only offered on the BMN window switch.
Old Sep 8, 2005 | 06:03 PM
speedz06's Avatar
Man! I am doing the tps switch but I cant open the diagram due to it being in microsoft office excell or something.Any help would be appreciated or maybe you can describe wich wire at the pcm to use?
