Update MAF kit SPY Photo.
NXRICKY: What about it, Ricky? Could you fellas whip up some rear MAF ends from the existing kits with those solenoids mounted on them for our multi-piece MAF sensors? Maybe also provide them as upgrades to those with the existing setup? They'd sell like hotcakes!
Bug the hell out of Ricky until he tells the machinist to make it happen
needed tools for kit install: allen key for MAF dissassembly, drill for switches, drill for bottle brackets, 2 wrenches for bottle bracket installation, screwdriver to remove interior parts to run wires.
Total time : 1 to 2 hours.
A 5 year old that can put together a model could install it... that alone should bea big enough sellign point to make it happen!
Rickey, get on it man!
, 10 minutes to mount the bottle,
, Run the nitrous line about 20 minutes,
, start b-s'ing an hour,
, Runner the fuel line 1 hour,
, What were we doing oh yea, hook up the electricallllllll . See it took take alittle longer...
RICKY! Make it so!
Ricky
I would not want to put up with all the BS you have to (like dealing with me and the others,
). This is what I see Ricky doing most of the day,
, haha. I wouldn't mind having the R&D/Prototyping job though...I would even do it for the same pay just to be able to design and play with products.I also retract my previous statement about bugging Ricky. Everyone leave him the hell alone so he can get these parts finished for you guys.....and so he can finish that car of his
If you need a test car for that setup for the 3 piece MAF, lemme know, I'm in good with a shop taht would be more then willing to do something with ya, they are nitrous guru's over there at Eastside, I'm sure they'd love to see the setup and do a before and after dyno results and all that for ya.
I'd be happy to give ya real world track #'s with it on and off too.. give me an excuse to go back to the track
Way too much money just to start a fuel jacuzzi in your plenum. I would never run a wet system on an LS1 and especially not spraying fuel there. A simple nozzle and a single solenoid can do the job twice as good in dry configuration.
I also wouldn't run a MAF either, but that's another story. Thing looks to be only slightly more restrictive than the usual MAF gear.
Let's see:
overpirced check
restrictive check
can't hide it check
fuel jacuzzi check
backfire in intake pending
I qualify my overpriced statement by comparing it to equipment for a dry system that will do a better job. No matter what it costs, it's too much.
Or add pure oxygen when you light your cigarette...after your nose is relocated explain again why excess fuel is required for an explosion. Buzz word here: Catalyst Last edited by cantdrv65; Jul 17, 2005 at 04:28 PM.
Only cars that came with the newer one-piece MAF sensor (2001+ Corvettes) or other cars that have been retrofitted with the one-piece MAF sensor can use the new MAF system.
, So the jetting max will be a comfortable 200hp. Still flowing for the larger noids, should end up around 350-400 hp
..... Now I am faced with a delema.
I would like to know if yall would like to see inbetween jetting come with the kit....
Right now I have flowed jetting hp as follows.
35-50-75-100-125-150-175-200. All these setting might be in kit from the get go.
Ricky
Ricky
I say do a generic jetting of 50-75-100-150-200 to keep the cost down...unless the extra jetting isn't going to me much more...in that case, the more jets the better.
P.S.
The kit looks
Myself, a guy that wants to get his car into the low 11's on motor, and run mid 10's on the hose, with a car that will be going to more car shows then it will race days, could probably put this to good use.
HMMM interesting thinking, already ooopppppss..
Now show us mustang guys some love
And the Mustang are about to get a huge shot in the arm.
Pateint to all who can wait..
Ricky
Now this interesting...
Ricky
need a test bed?
Ricky
Robert
Robert
I will not tell anyone.
Ricky
