need help
Old Jul 12, 2005 | 07:56 PM
2001z's Avatar
Default need help
can someone take a pic or tell me how the hell the wot switch and braket mount in the throttle body.
Old Jul 12, 2005 | 11:27 PM
code4's Avatar
OK, here's how I did it. But I don't know if your bracket/switch is the same. I took the 2 bolts out that hold the throttle cable bracket to the intake off. I found longer bolts & put spacers in to bolt the WOT bracket onto this bracket. You have to get just the right amount of spacing so that your throttle hits it just right. I did not have to bend the WOT bracket at all. Here is a pic with the throttle at Wide Open it works perfect. I think most others do it different by bending the WOT bracket somehow.
Old Jul 14, 2005 | 07:54 PM
2001z's Avatar
thanks man that worked great i used 3 1/4 in washers behind it and it is straight
Old Jul 14, 2005 | 10:27 PM
code4's Avatar
I'm glad it worked.
Old Jul 15, 2005 | 02:56 AM
JustAnIlluzion's Avatar
u can also mount it underneath the gas pedal
