Bigger nos noids??
Old Jul 16, 2005 | 12:16 AM
Nasty Hawk's Avatar
Default Bigger nos noids??
Currently running the NOS 5177 kit with no jets. Could i change out my noids to biggers ones so it will flow more than 140shot? If not i will probly set it up dual stage style dry/dry..
Old Jul 16, 2005 | 12:24 AM
white2001s10's Avatar
Well the nozzle will start becoming a restriction around 200hp @900psi.
I'd go ahead and add another nozzle and stage it.
Old Jul 16, 2005 | 12:46 AM
Nasty Hawk's Avatar
Been doing my homework and will probly go with the dual stage. Going to order another window switch with first gear lock out for the second stage. will probly run a 125 jet in each one, which should only be about a 200 shot correct?? Dry shots are usually less..
Old Jul 16, 2005 | 12:13 PM
GM Muscle's Avatar
Yeah, if you break that up into a 2 stage you can use the noids you have. That dry shot jetting should be correct for flywheel horsepower. I would not go over a 200-225 shot at the crank. You might find yourself running out of injector though.
Old Jul 16, 2005 | 04:42 PM
Robert56's Avatar
You can also just split the redundant noids up. The 5177 has the blue tee in between the noids with a pipe plug in it. Use this for your supply line in. Then turn one of you noids around so they are both in/out. Then one noid/one line to each nozzle, limit is now about 140hp each side. Now you can over come the 140 limit single stg and it's also ready for dual stage when you want. Check out my web for some pics of the 5177 as a dual stage.
Robert
