Running Lean?
Old Jul 19, 2005 | 10:44 AM
sickss228's Avatar
Default Running Lean?
I pulled my tr6's(gapped at 35) out and 6 out of the 8 were done the ground straps and porcelin were melted away. I know it's running lean but what should I trouble shoot? I have the correct jets installed for the 75 shot my car has 58k with a brand new racetronix pump. Could it be that some of the injectors are clogged, should i run the 100 fuel jets with the 75 nitrous jets? I run a cartek timing retard module, and always run amoco or sunoco 93 octane and the car seems to run fine NA.Any help is appreciated
Old Jul 19, 2005 | 11:13 AM
calongo_SS's Avatar
how much timing are you pulling? sounds like you were detonating pretty bad.
Old Jul 19, 2005 | 11:22 AM
Noyzee's Avatar
8 second mod
what is your fuel press? sounds like she isnt getting any.
Old Jul 19, 2005 | 12:28 PM
GM Muscle's Avatar
Can you post any pics of the plugs. Sounds super lean to me. I would start by testing the fuel solenoid and checking the fuel jets to see if there is any junk in them.
If you melted the plugs that bad I would be doing a leak down test, or a compression test at the very least.
Old Jul 20, 2005 | 02:27 PM
sickss228's Avatar
I can't post any pics I'm currently deployed overseas I'll be returning in 2 months. I just wanted to know how I should troubleshoot it when I get home. I dont have a fuel pressure gauge,I'll have to get one, and I'm pretty sure the timing module pulls 4 degrees. The system is brand new, and the solienoids were working when i installed it. Thanks for all your help
Old Jul 20, 2005 | 02:50 PM
Noyzee's Avatar
8 second mod
sounds to me check fuel psi not just at idle, check it during a pass, or at WOT on the spray. seems like that is it.
Old Jul 22, 2005 | 09:36 PM
MDoe8's Avatar
get a fuel pressure safety switch and put it on! Sounds like not much fuel is mixing with your nitrous
-Mike
Old Jul 27, 2005 | 02:05 PM
sickss228's Avatar
Thanks for the help guys I'll check it out as soon as I get home
Old Jul 27, 2005 | 04:01 PM
Wile_E's Avatar
When I put my car on the dyno to check the A/F ratio while spraying, I found that the recommended jets caused me to be lean. Right now, I run the #52 jet for nitrous (for 100 shot) and the #35 jet for fuel (for 150 shot).
I would recommend finding out one way or another what your A/F ratio is while spraying without just assuming the recommended jets are the correct ones.
Old Jul 27, 2005 | 04:10 PM
SDB's Avatar
SDB
.4 and 6 mph on a 75 shot is not terrible (per your sig)....the plugs being broke is very bad...
I would test the solenoids, call NX and they can tell you how much the fuel and nitrous solenoids should flow at a certain jet for a certain duration of time.
check FP with a gauge while on a dyno, and do AF ratio as well...
sounds like your lucky your engine is still running!
Old Jul 27, 2005 | 08:40 PM
calongo_SS's Avatar
It's possible the piston in the fuel solenoid is swollen and that was causing you to be lean, or your fuel pressure is too low, or the bottle pressure was too high. The jets they reccomend are correct for an out of the box kit if the conditions are on your car are what they should be.
Old Jul 27, 2005 | 09:11 PM
Wile_E's Avatar
My solenoids had just been to Nitrous Express for servicing. My bottle pressure was at 950 but I am on the stock fuel pump with almost 500 hp at the wheels.
I'll have it back on the dyno after I get my Racetronics pump installed. Maybe that is the reason why I needed a bigger fuel jet.
Old Jul 28, 2005 | 08:57 AM
calongo_SS's Avatar
I bet that will get everything straightened out.
