Direct Port Help...
Old Jul 19, 2005 | 11:42 AM
jaredwayt's Avatar
Default Direct Port Help...
im thinking about going to a direct port setup, it will be on a c5.i was wondering if i ran only 150 shot, would the stock injectors/fuel pump be sufficent, or would i need new ones...
would it be possible to run a DP system with a WOT switch, and a rpm window switch...
also, if i decided to go with some aftermarket fuel rails, what would i need to make them fit with all the other stock parts, will the just mount up...
thanks...
Old Jul 19, 2005 | 11:46 AM
Nitro Dave's Nitrous Outlet's Avatar
Your stock injectors will be fine.However I suggest Depending on your mods you may need to upgrade the stock intank pump.A directport requires more fuel at one time.Yes I recommend running a windows witch and a wot switch.
Let me know if I can help you put together a system to fit your needs.
Dave
