nitrous newbie ???
Old Jul 23, 2005 | 11:20 PM
REDWS6ROCKET's Avatar
Default nitrous newbie ???
whats up guys? i have a few ? for you nitrous gurus. mods in sig what would be a better and safer for my set up a wet or dry shot. any other supporting mods fuel and spark wise. nothing to big maybe a 50 or 75 shot just for some extra getty up every now and then. thanks guys
Old Jul 24, 2005 | 01:39 PM
Matt@HSW's Avatar
Either kit would be fine for a 50 or 75 shot. You might run into a problem if you go with a dry kit and then you want to move up to a larger shot. A lot of guys start off with a "small" shot but with it so easy to change out jets they start moving up. If you have a dry kit and start moving up you might have to get some larger injectors and a new tune. If you start off with a wet kit and want to move up to a larger shot you don't have to worry about the injectors. It comes down to what you want to do with your car.
If you're going to be spraying with a cam (I see you already have heads) I would look into upgrading your fuel pump. The Racetronix kit is nice as it comes with everything. Make sure you change out your plugs to a set of NGK TR-6s or something similar. For the nitrous kit pick up a window switch and a fuel pressure safety switch. A bottle heater and purge are nice to have too.
Matt
