#10 wire on a 2000 z28?
Old Jul 26, 2005 | 11:47 PM
camrsz's Avatar
Default #10 wire on a 2000 z28?
can anyone tell me which wire in the harness on a 2000 z28 camaro, is #10? or tell me where a diagram or something is that i can find this information? I am trying to install a digital msd window switch.
Old Jul 27, 2005 | 12:25 AM
BoostMluse's Avatar
pcm pinouts
There should be a white wire on the red c2 connector, pin #10. That should do it.
Old Jul 27, 2005 | 08:04 AM
GM Muscle's Avatar
Yep, you need to pull the cover off the top of the PCM plug. You will see that each PIN is labeled.
