NX/Nitrous Outlet EFI System Installation Help Needed!
No, I have no idea about the purge exit nor where I can locate some thin, black tubing for that purpose. Any suggestions would be appreciated.
Finally, I want to install the NX switch console assembly in the ashtray area, but how do I get to the wiring behind there? Do I need to cut out the plastic that's left back there after I pull out the ashtray? Do I need to remove the stereo head unit bezel and, if so, how do I go about doing that? Thanks again!
On the ashtray wiring, if your careful you can set it back up to stock when selling, as I have done that and you can't tell it was ever modded. Yes the plastic behind the ash tray has to be cut, but ash tray will still fit and work later. there's a aluim brkt behinh ashtray that a screw (?) goes into that needs cutting or bending. I cut mine because once the ashtray pleastic is cut the screw won't be going back anyway. Under dash on pass side you can push wires up into switch area as needed without removing console after intial removal for cutting. Here's a pic just to give a idea of how much can fit in there, and there is more now than this pic. Stereo stays put. I have 5 switches and three lights in the ashtray area. I used the lighter hole for my purge button and all can go to stock later.
Robert
Robert
Robert
One more then I will focus on the nitrous. I can't wait to get a report from you X,,,,,,,I want some feedback on what this stuff is like
Also, congratulations on your test score and good luck with the career.
I am going the NX switches in the ashtray and also a NX Electric N2O Pressure Gauge where th ecig lighter si and I shoudl still be able to close the door.
Good Luck and thanks Robert, Wolf, and everyone for all the info and pics, they help out a lot!
I too would like to again thank everyone for their help. It's been invaluable to me.
Anyway, I removed the plastic and cut out the metal to mount my console switch assembly and want to start making the electrical connections to it, but I'm trying to figure out how to get wires from the passenger side of the underdash area to the ash tray area where the switch assembly is going. How do I remove/release the bottom portion of the passenger side dash so I can reach up the behind the ash tray with some wires? Thanks!
P.S.- I see what looks like some plastic buttons/connectors, do I just pry them out? Thanks again!
