what Kit to chose and not hurt the engine
Old Jul 30, 2005 | 01:00 PM
Brichdp06's Avatar
Default what Kit to chose and not hurt the engine
What NOS kit should i go with if i want to use it at the track and certain times on the street and not hurt my car. What all would i need to do and what kit and shot should i go with?
Old Jul 30, 2005 | 03:26 PM
Robert56's Avatar
Not knowing what car you have (assuming a ls1) and understanding you want a NOS brand kit, I would suggest the 5177 dry. It's a very popular kit and very safe. also a very easy install and no mods are needed. However I would get rid of stock plugs as they can become blow torches. these kits with a basicaly stock engine can use stock injectors, fuel pump, tune, timing and includes everything to get started. They can be later set-up for up to 300hp dry or converted to wet, or set-up as dual stage dry/dry or dry/wet. A very good starter kit. A window switch is not included and is rec by most. have fun with the giggle gas, you'll love it. Also, the vendors on this site offer small dry kits also as an alternative if you like.
Robert
