So with the Zex kit....?
Old Jul 31, 2005 | 06:00 PM
joblo1978's Avatar
Default So with the Zex kit....?
With the Zex kit, do you need the following for best safety? You can't even install these if you wanted can you? That little box does all of these things?
-Fuel pressure safety switch
-Window switch
-WOT switch
I really like the ZEX kit! I'm looking into Nitrous and think the simplicity and ease is really cool. I don't mind the purple either.
Old Jul 31, 2005 | 06:04 PM
pman's Avatar
You need window and FPSS. The box just does WOT switch and has a N20 pressure sensor to adjust fuel. You set the WOT switch off TPS output signal to the ZEX computer.IIRC blue wire of TPS.
Old Aug 1, 2005 | 06:19 PM
BTLFEDSS's Avatar
You would still need a window switch also
BTLFEDSS
Old Aug 1, 2005 | 07:53 PM
pman's Avatar
Old Aug 5, 2005 | 01:27 AM
ws6formula98's Avatar
Default Zex Wet Kit Promble!!
After Puting The Zex Kit In My Ls1 98, I Went And Try It Out. But When I Turned It On, And Hit The Gas, Nothing Happen. I Thing It Was The White Wire That Goes To The Sensor. Which Color Wire Does It Go On? I Have It On The Gray Wire (i Think)or What Could The Problem Be?
