TNT Install
Old Aug 6, 2005 | 02:42 AM
LoWeLL216's Avatar
Default TNT Install
Ok, started installing a TNT F1 system. I've mounted the bottle and run the lines. Before I start connecting things I have one question. Which fittings need loctite / teflon paste and which don't? Thanks in advance!
Old Aug 6, 2005 | 02:57 AM
Super Speed's Avatar
I'd do it to all of them man its not gonna hurt them and its easy to do
Old Aug 6, 2005 | 04:51 AM
AgFormula02's Avatar
AN fittings DO NOT use any sealant. Only use it on the NTP connections, and for those, use limited quantities.
In other words, if it hooks up to a nitrous line, no sealant.
If it going into the noid, then use a small amount. (You will see what I mean, if NPTside is flat while AN is flared.)
Old Aug 6, 2005 | 08:13 AM
TNTramair's Avatar
dont wanna use teflon tape either...one little piece of tape breaks away it will get stuck in your noid and than your screwed!! so be carefull.
