Is my car leaning out because n2o?
Old Aug 11, 2005 | 06:46 PM
SlowTA98's Avatar
Default Is my car leaning out because n2o?
My car burnt a valve last pass down the track. I have n.o.s the big solenoids a -4 fuel line off the rail going to the fuel side then out of the slolenoid i spit the fuel between 2 nozzles.-4 nos line going to nos solenoid and then split coming out betweent 2 nozzles.There is a 255 intank pump and 30# Ford motorsport injectors with stock fuel lines.The reason for 2 nozzles is i could not get any more than a 100 shot per nozzle.The n2o tune was good with a 12.0-12.4 air fuel on the wide band o2. Is the fuel system on the car capable of suppling enough fuel for motor and a 175-200 shot?
Old Aug 12, 2005 | 08:58 AM
Nitro Dave's Nitrous Outlet's Avatar
Whats done to the car mod wise.If you have heads cam etc. you are probley running out of fuel.If so I would check into one of our dedicated fuel systems.
Dave
Old Aug 13, 2005 | 01:56 AM
Sukkoi19's Avatar
Its a H/C/I built motor car. What specifically is running out of fuel on it though? The actual lines or the pump. The plan isnt to stay nitrous forever, so spending money on a dedicated nitrous fuel system really doesnt seem like an option. However if the stock lines cant keep up, upgrading to a fuel system will work for a different application as well as the nitrous.
