Installing BMN window switch
Old Aug 13, 2005 | 10:22 PM
LoWeLL216's Avatar
Default Installing BMN window switch
So I'm insalling the BMN switch and it says to hook into the brake light switched power. Is there some reason why you hook into this (convenience?) or can you hook into any 12v switched power (TCS switch, etc)? Thanks!
Old Aug 14, 2005 | 12:16 AM
gollum's Avatar
It just makes sense to use the brake pedel switch for resetting first gear lockout. Because after a run "you will" apply the brakes to stop. But I guess you could use some other type of switch. I haven't gave it much thought.
The brake pedel switch located under your dash has two wires leading to it ORANGE and LIGHT BLUE. Connect to the LIGHT BLUE switched side wire.
Old Aug 14, 2005 | 12:44 AM
LoWeLL216's Avatar
That's what I was wondering. So the first gear lockout is reset by the activation of the brake pedal?
Old Aug 14, 2005 | 09:09 AM
gollum's Avatar
Yes that is correct.
