timing tuner question?
with the timing tuner is it possible to not have it take timing out until .4 seconds in.
meaning i want to run the best i can N/A for that .4 seconds and then hit the juice with some timing pulled.
this is "hypathetical" but i may have to do this later.
i thought as soon as you flipped the arming switch it did take it out....
do you have first hand experience?
how does it know when to take the timing out?
I'm up at the line. I arm my kit, turn on fuel pump, and purge.
i prestage
brake stall to about 3500
stage
i go WOT with no timing pulled!
(.4 seconds later) i now want my N20 to active and spray and pull 3* timing.
does that make better sense...
i want to run NA off the line because it wont hook... then activate and pull timing.
hope that wasnt confusing
thanks!
Tyler
okey dokey... just making sure i understood what you understood...
hahah.. confusing .... thanks bro.
