Dry shot at 2000 rpms?
40ft is a guessimate.
either way, it's WELL below 3000 rpms. the magical do not hit it under mark. as i said in the other thread, whenever you want to meet me at bradenton and watch for yourself, i'll oblige.
Sounds like great actual real world FACTUAL DATA to work with there.
Yes..im being a smartass. But there is a reason why people that have been down this road before do things the way they do them.
If anyone is going to try to hit juice lower than 3000 rpm I would HIGHLY recomend a window switch. Set it at 3000 rpm. Make a pass. Set it at 2900 rpm...make a pass...etc,etc. As you begin to go lower in rpm..ask yourself if you would have no problem spraying double the HP at double the rpm. IOW...if you spray a 100 shot at 2000 rpm...would you be comfortable spraying a 200 shot at 4000 rpms? because thats about what it equates to. A 175 shot at 2000 rpms is gonna see similair cylinder pressure to a 350 shot at 4000 rpms etc.
a window switch is only as good as the computer that built it. SSSOOOOOO you actually believe a window switch is accurate? i just love those wonderful little items. especially those one with that special if your rpms are within 200 rpms of activation when launching, you don't get activation. go ahead and set it for 3000 rpms, then launch at 2800 rpms. damn it, just lost that race. oh well, at least i'm safe.
so what if it does see the same cylinder pressures. if the motor can't handle the pressure, it won't matter at what rpms you hit it at. yes, it does put more strain on the rotating assembly. but even you can't say at what rpm is too low.
and just how much does a stock tach actually LAG? let's have some of that FACTUAL DATA on that. last i checked mine, it was off maybe 200 rpm at 6000 rpms at most according to the tach readout on the dynojet i use. 3000 rpms on the dash read 3000 rpms on the dynojet.
we'll go at this for about two days. all this trying to discredit me just like the last thread. it's nice being the moderator though. you can have the last word and lock it.
have you ever tried hitting the bottle below 3000 rpms yourself? apparantly not. you just go by what you're told don't you. i've hit it at 1500 rpms according to the tach in the 99TA i had. tires spun, so can't do that. back to 1800 rpms it was.
that's the difference between you and me. you only do what you've been told can be done. i test the waters and go against the grain. believe none of what you read and half of what you see.
ok time for some real world FACTUAL DATA. see the above car. it belonged to mike senia of Yank converters. they enlisted vinci high performance to test a whole slew of their converters. the motor was a complete stock short block except for cam. this means stock pistons, crank, and rods. the testing was done in 3RD GEAR at 0 MPH starts. they even did 150 n2o runs in 3RD GEAR. right now, Yank's site has been changed over and i can't find all those wonderful graphs they had up. i will though. he wanted his converters put to the limits. there was no care about the trans or motor. he had backups. tell you what. call up VHP and mike senia @ Yank about it.- motor never let go. never.
I have in fact sprayed more cars without window switches than with, however, I understand what I am doing, some new guys may not.
Example, an automatic with a dry hit, I have no problemo spraying outa the hole. Now, what that means to me is, powerbraking a bit to take rpms up, then on launch flooring it and by time the n2o is hitting the clys, rpms are up and out of danger. I have not hurt any engines this way.
Furthermore, if you are really serious about racing, the human factor needs to be eliminated wherever possible. Meaning, a person will never be consistant reaching over and flipping a switch, compared to electronics that will do an absolute evertime. This reasoning can be seen in the choice of transmissions in racing. The auto is prefered because it is consistant, whereas, the manual is much, much harder for the average guy to get right.
I have my ws set at exactly 3000rpms, a little lower is acceptable. But try a stick shift with a wet kit coming off idle. See what I mean, a new guy may not realize these things. I do give you kudos for allways stating, do at your own risk, type of thing.
About cly pressures at below 2500rpm, it's like doubling your shot, that's how high they become, and that was the point being made.
We have different opinions, maybe/maybe not, it a forum for information and that's what we all are doing yourself included.
Robert
Robert
Robert
Robert
yeah right. that's why i've got this moderator coming into this post and saying this right here.
i'm sure i really don't need to pull up the other thread. the day he's in my car and watches what i do, is the day he can tell people that i don't know what and when i'm doing something. i've never come in here telling people that he doesn't know what he does or how he does things. there's no need for his UNFACTUAL DATA comments about what and how i do things.
i'm ok with anyone's disagreeing about what i say. that's opinions. but, never tell me what i do and don't do.
http://stealthram.com/1999TransAm.html
The window switches I have used are pretty damn accurate. A thousand times more accurate than attempting to watch a stock tach at WOT and trying to guess your rpm, then flipping a switch. As far as doing what Im told...lol..hardly. I try to do what logic dictates and experiance has shown me to do. As I said...there are MUCH better ways to get down the track faster than to spray a 175 shot at 2000 rpms.
wheres the factual data???? And what does 0 mph have to do with engine rpm? If its a stalled car then its going to probably be fairly high. And if its a stock stall...at what rpm did they spray it. I dont see any data??? If you pull up a Yank graph clearly showing nitrous engagement at a VERY low rpm that would be nice.
The biggest tell tale sign that you are well beyond the 1800-2000 rpm you claim you are is that you say you are approx 40 feet out from the line before juice is engaged. There is no way...even on the stock stalled car you are at 1800 rpm at that point. Bottom line is...YOU HAVE NO IDEA what rpm you are on engagement. Want to prove your claims that a 175 shot is safe at 1800 rpms? Put in a window switch and set it to 1800 rpms and spray your 175 shot by mashing the pedal off the line. DO that about 5 times in a row on the stock stalled car and then i will be a believer.
It would be good if it stays that way and if some more data were posted because I'm learning a lot from everyone here about nitrous usage.
Thanks for all the info ... would be nice to hear from other experienced folks who've sprayed a lot over the years. At the dragstip, soon, I want to stand my car straight up ... but not BLOW it up. Keep the flow of knowledge coming.
was just over at macedo motorsports the other day. the a/f ratio was off by almost a full point because the wideband o2 took a crap. but hey, it has to be right. it's a computer. man, how did this world survived without computers is beyond me.
The window switches I have used are pretty damn accurate. A thousand times more accurate than attempting to watch a stock tach at WOT and trying to guess your rpm, then flipping a switch.As far as doing what Im told...lol..hardly. I try to do what logic dictates and experiance has shown me to do. As I said...there are MUCH better ways to get down the track faster than to spray a 175 shot at 2000 rpms.
computers are too fallible. while safety items are nice to have and can save your motor, i just prefer the good old fashioned human control. while not CONSISTENT, alot less things go wrong. i do have a FPSS, who wants it? still sitting in my tool box.
i'd rather be off a couple hundred rpms, or a .1-.2 off in ET than have electronics failures and cost me the race.[/quote]And IMO your method for saying that spraying a 175 shot at 2000 rpms is A-OK is less than sound. I honestly do not believe you are spraying a 175 shot at 1500-2000 rpm.[/QUOTE]
apparantly it is A-OK as i'm not the only one doing it. as evidence of two others in this thread saying they do it. why don't you go bother them about? haven't seen you say anything to them. seems like you are singling me out. so, until you spread some of the criticizm around, back off.
And Im not really trying to attack your credibitly as much as show you where you may be missing a few things. otherwise I would not type the lenghty replies.
As far as the stock tach and it being off for you by only 200 rpm....first,,,the tach lage relative to acceleration. SO it biggest lag point will be at peak Tq. It may catch up slightly in the upper rpm ranges. But I want to ask...what method were you using to see that the tach was off only 200 rpm at 6000 rpm? Where you watching the dynojet rpm as you watched the stock tach as you did a WOT run? Seems like that would be pretty difficult under rapid accelration. Eyeballing two tachs during a dyno run seems tough. Its hard enough for me to eyeball the stock tach and the Autometer tach and they are side by side.
As far as the Yank car....having 50 runs in thirds from a stop all motor is no huge stress on the shortblock. Now if your saying they sprayed it all 50 runs off idle with a 150 shot in third gear from a stop...that would be impresssive. I would like to see the graphs.
As for Mecedos wideband...it was off...so what. What would you use to tune if you had no wideband? Are you going to be reading your plugs and making adjustments from that? There is a reason why widebands and electronic devices have taken the performance world by storm that last ten years or so. It has a direct relationship to all these extremely high HP cars that run around on the street now reliably and safely. It has also promoted the incredibly quick ETs we are seeing. Technology is a great thing in the racing world.
or someone with outward crossed eyes. and technology is a great thing. if i didn't think so, i'd have the edelbrock/MSD intake and timing controller on this thing already.
i'm not against using any electronics. on my 86TA i bought a NOS progressive controller. i sepnt $315.00 and gained nothing. reason why is i wasn't losing traction to begin with. so, the help wasn't needed. i'm more than willing to meet up with you and do some datalogging. just to see how far off the tach really is in comparison. if i'm not hitting it at 2000 rpms, i'll be the first to post it. until i datalog it, i'll believe my tach. i'm really not here to argue and throw mud either. i like to learn. i don't think i would've ever went to 200 motor rating if i hadn't read on this board people doing 250.
