Dry 100 Shot or Wet 100 shots?
Old Aug 31, 2005 | 10:59 AM
Race Car Driver's Avatar
11 & 7 Second Clubs
Your question has been covered more extensively than Hurricane Katrina. A 100 dry shot is less costly, easier to install and a little safer.
Old Aug 31, 2005 | 12:21 PM
98Z28MASS's Avatar
True, I did some searches and found some answers to my questions. I just wanted to hear first hand who has run a 100 dry shot and a 100 wet shot and what the difference was wear and tear wise on the car, how long they have run it without any problems, and which was safer and easier to install. I appreciate your input and I think im gonna go with the 100 dry shot for now.
Old Sep 1, 2005 | 02:43 AM
cantdrv65's Avatar
Post
Originally Posted by napoleon
i have said it once, i will say it agian. The intake mannifold is not made to flow anything heavier than air(I.E, octane)
You do realize nitrous is also heavier than air? Personally, I ran a wet shot of varying sizes for the life of over 80,000 miles of my car...NOT ONCE did I see a backfire! And I purged the line by blocking in the bottle and spraying the remaining N2O Fuel until only fuel remained and bogged the engine....Literally HUNDREDS of times... "Fuel puddling" is a myth, nothing more.
Old Sep 1, 2005 | 08:56 AM
Nitro Dave's Nitrous Outlet's Avatar
i have said it once, i will say it agian. The intake mannifold is not made to flow anything heavier than air(I.E, octane) and i have seen NUMEROUS large shot(125-200) blow intakes off the car. IF thats all it does, your still out of an intake, MAF, etc. But it can rip bolts out, as well as do other things. you can also have the cylinders closer to the front get more of the gas than the rear..introducing a rich conidtion in the front and lean in the rear. you would probly be fine, but that ONE time!
No!!!! User error blows intakes off cars.Follow the guid lines and use the safety equipment and have fun..................
Dave
