NX kit/system question
I'm curious about something. I have a standard NX GM EFI wet kit and want to eventually run a dry dual stage. Is it possible/advisable to run nitrous through both sides of the nozzle?
Actually, I'm asking for all NX kits...Plates, Shark/Pirhana DP's, EFI nozzle kits, etc. Can I run nitrous on the fuel side of a nitrous plate or nozzle?.
yes you can run it on the fuel side. How much it's affected I'm not sure. By what I mean by affected is the flow of nitrous. the nitrous is on the far side and when fuel flows down the nitrous blows through the fuel atomizing it. should still work though.
ttt for NXRICKY if he is reading. Let's make a good example here. if I wanted to take the gemini plate and run a two stage dry setup vs. a single stage wet. Can it be done? Can i run nitrous on both sides up to mayb 150-200hp and not worry about having problems.
