First Nitrous Dyno Numbers!
These numbers are SAE with the converter unlocked, spraying a 75 shot to 6000 rpm. I'll likely increase my upper rpm limit to 6200 rpm, so I should see slightly bigger numbers next time, but these initial ones aren't too bad.
441 rwhp @ 6000 rpm 418 rwtq @ 5100 rpm
I would think the tq would be higher
Nice #'s though
Gary
Nice #'s
Good luck with your installation!
Nice #'s though
But if you are spraying at 3,000rpm on a WS etc, then its low...who cares about a dyno # as long as the track times are there anyway!
But if you are spraying at 3,000rpm on a WS etc, then its low...who cares about a dyno # as long as the track times are there anyway!Robert
Robert
Robert
I have a 4000 stall and my shift extentions (where the rpm's drop down to between shifts) is 5,200 and mine shifts at 6,500 so I am not sure where to set mine either.
I have a stock tranny, so spraying through shifts is a sure fire way to blow that tranny up fast. I think prolonged use of nitrous will blow a stock tranny anyway, but through the shift will get you there faster.
I was going to set my BMN switch at, hmmm I don't know. 4,000 and 6,400. I haven't got that far in the install yet.
Thanks
Gary
Robert
Is it easy to change the dials on the rpm?
Trooper, PLEASE tell me what it FEELS like? Are you spraying 100 or stilla 75? What exactly does it feel like and how does it come on?
Does your car FEEL MUCH faster, or is it deceptive speed?
Thanks
Gary
Just my opinion, especially with you only doing a 75 shot (at this time!). Anything higher and being on the side of "caution" is probably a good thing; less items broke! Either way you are having fun and that's the name of the game!!!!
Redcoupe, 4000 stall on the juice for a street/strip nitrous car is a little much, imo. Now if you were reving to 10 grand and had 5.xx gears then ok?
Robert
Also, I see X-Trooper has a SY3500 with a 1.68 STR (Stall Tourqe Ratio) and I have an SS4,000 with a 2.60 STR. My converter is much tighter, but also has 500 rpm's more stall.
Gary
Gary
Robert
. Oh well, NA I will still be a monster
X-Trooper.............I saw a comment on Corvette Forum about not getting your TPS Switch to work.
What Happened? I bought one after the fact just because my installer said they were easier to work with. I am installingn next week.
What specifically was your problem with not getting it to work?
Gary
