Can I really?
Old Sep 5, 2005 | 05:38 PM
El Tiviris's Avatar
Default Can I really?
After reding a couple of threads I relize i whant nitrous.
Can I realy use a 100 shot on a stock Z28?
(has 65k on the odometer)
How much is safe?
Any people had bad times on Nitrous?
Old Sep 5, 2005 | 05:47 PM
setxws6's Avatar
Yes.
Depends on how much hp on bottomend of motor.
People that have bad times, are ones with wrong tune or not enought fuel to engine.
The search button is your new best friend...use it.
Old Sep 5, 2005 | 06:09 PM
XTrooper's Avatar
How much is safe?
1. Yes, you can spray a 100 shot on a stock LS1 motor.
2. That depends on how much horsepower you're making on the motor, what kind of kit you buy, and if you've upgraded the fuel supply system.
3. Yes, but people have had plenty of "bad times" without the help of nitrous also.
Old Sep 5, 2005 | 07:41 PM
Matt@HSW's Avatar
Sure you can safely use a 100 shot on your stock Z28. Make sure to change out your spark plugs to a colder set (like some NGK TR6s) and pick up the safety stuff, like a window switch and fuel pressure safety switch and you'll be good to go.
Matt
How much is safe?
Old Sep 5, 2005 | 10:48 PM
Nitro Dave's Nitrous Outlet's Avatar
Yes you can easly spray a 100 shot.I suggest buying a quality system,Like NX and running the needed accessories.If you go to a 150 shot I suggest upgrading your stock fuel pump up to a walboro 255.
Dave
