175 Shot + SES
Old Sep 8, 2005 | 01:09 AM
Somebody09's Avatar
Default 175 Shot + SES
So... I ran my car pretty hard the other day with a 175 shot and my SES started blinking. From what I know, that means misfire. A/F was somewhere between 11.8 and 12.5 the entire run. After about 15 seconds it stopped. It didn't do it the whole ride home, but I never sprayed anymore either. Should I be worried? I'm gonna check my plugs and wires to make sure all is good, but has this happened to anyone before?
thanks
-somebody
Old Sep 8, 2005 | 02:41 AM
strokedls1's Avatar
Blinking ses means you have a major misfire problem. With that big of a shot unless you decreased the gap on the plug it could have blown out the spark. Are you at least using a tr6 plug. I would swap all the plugs out and check the condition of the ones in there to see if there is a lot of discoloration or pitting from a lean or knocking condition.
Old Sep 8, 2005 | 05:42 PM
LETZ RUN's Avatar
i had a flashing SES light and it wasnt the misfire code it was the fuel trim lean code, that was before my walbro 255 was installed.
Old Sep 8, 2005 | 06:08 PM
Matt@HSW's Avatar
Pulling timing? How much total? How is your fuel system set up?
Matt
Old Sep 8, 2005 | 08:27 PM
Somebody09's Avatar
I've had TR6s for a while now and gapped at .035. I have Racetronix's PNP pump for fuel, and throughout the entire run, my A/F was high 11s. No timing pulled yet... I'm still waiting for HPTuners' package to arrive.
I'll check the plugs though.
Thanks,
-somebody
Old Sep 8, 2005 | 08:44 PM
Matt@HSW's Avatar
Scan the computer too, there should be a code stored.
Matt
