Spray Activation
Old Sep 19, 2005 | 06:38 PM
BlownChevySS's Avatar
Default Spray Activation
I have never used nitrous before so sorry in advance for the stupity. I got it all hooked up wiring and all. Just curious though how I would get it to jet when I shift into second without a window switch.
I would obviously open the bottle, put power to the solenoids, but when the wot switch activates when the pedal is floored when i punch it out of the hole, I don't want the nitrous to jet yet. I would I only get it to do it in second?
Old Sep 19, 2005 | 07:39 PM
kman0066's Avatar
I'd imagine you could put a normally open switch in the circuit on the shifter that would be touched only in first and once you were out of first it would close activating the circuit, you'd have to be careful to be off the pedal though when you go to pull it out of gear.
Old Sep 19, 2005 | 10:36 PM
code4's Avatar
Check this thread out, picture on #9
https://ls1tech.com/forums/showthrea...+gear+lock+out
Old Sep 19, 2005 | 10:44 PM
Sorry. I have an automatic silverado ss.
